Steering Wheel Play
kaylix
NY, NC, GA
Sugar Sand
Tango Xtreme
I have some play in my steering wheel, but it is frustrating. Is the control box under the helm serviceable ?
You can tighten up some of the screws in the linkage. Is there too much play in the wheel? (steering wheel moves, but does not move the cable)
There is about 5 degrees of play before the diverter moves. So when I'm cruising I'm constantly moving the wheel to keep tracking in a straight line.
@Bruce do you have any magic tricks up your sleeves ?
Sounds like there is excessive play within the gears in the steering box. I had to replace my entire steering box a few years ago because the gears broke. In the new box I got, I still have a little bit of "freeplay" in the steering. Not sure if the steering box I got was top of the line, but the gears on it don't mesh 100%. There's still some play. I took it apart and noticed there is a spring washer behind one of the gears and it wasn't pushing the gear into the other gear hard enough to create a full mesh of the gears. There was some spring play, which causes the "freeplay". Anyhow................ I ended up stacking a flat washer behind the spring washer and I get a little bit better meshing of the gears and not as much "freeplay" in the steering wheel.
Hope this wasn't too confusing.
Personally, I think the ones they use on these SS boats are about as low grade and cheap as they get.
I summary: I believe the sloppiness in the steering comes from the two gears in the steering box just don't mesh up tight enough.
This is the type of system that they use: http://turbojetmarineproducts.com/w...-Flex-Marine-JBS-Jet-boat-steering-system.pdf
(I'm trying to find a diagram of the gearing inside the box, but no luck)
Not confusing, I understand what you're describing.
Every boat I've owned has had this play issue. You'd think they would use really high quality tight parts for a primary system.
It sounds like I can open the box and have a look.
Be careful. Taking the box apart is simple. Putting it back together while it's still mounted can be tricky because of the washers needing to be held in place. I used some lithium grease to hold the washers in place.
@mrcid Where are you located? Have you winterized yet?
I'm a just north of Houston near Lake Houston. Have not winterized, yet. Still got a few weeks of boating/fishing left. Then I'll winterize............. to some degree. We really don't have winters here.
