drisso88
- FSH Sport
Finally pulled the trigger on an upgraded sound system, and have everything coming in on Friday. Went with the Wetsounds MC20 head unit, going to install it on the lower right side of the helm, where the 12v and aux input are. 2 questions, and probably dumb ones. 1- can I use the power wire that originally went to the 12v charger to power the head unit? Seems like the easiest option and I'd think that runs to the house battery anyway. 2- where can I wire in the 0/1 ga for amp power to the DVSR? Originally thinking I would follow the power wire to the OEM Wetsounds amp and just wire it there, but for whatever reason that is wired to my start battery. I want this system to be able to run only off of my 2x100ah lithium house batteries, while leaving my start battery off. I also noticed the DVSR says 140amp max, and with 0/1 ga I'm going to be running a 250 amp fuze so not sure if that's going to cause an issue. I'm sure this has been done a bunch of times and I'm probably overthinking it, so any advice would be greatly appreciated!
