Stereo install help/question
2nazt
Port St. Lucie, FL
Tidewater
I am in the process of linking the Yamaha harness to the Fusion IP600 unit. What is the blue (auto ant) with 1A fuse for? Is that not going to be connected in new harness? Or will it go to the blue remote line off the Fusion? Thanks in advance
It is normally used in a car that has an electric antenna, but is also used as the amplifier turn on.
So I am not running an app yet, but am installing BT100,so will I link to that per manual? I plan on and later just not in the budget yet.
I'm not sure where the BT100 gets its power from. Maybe someone that knows will chime in.
Manual says Amplifier on for 12v power.
Sounds like that will be your huckleberry then.
I just installed a fusion 750 tonight .. the blue wire is for the amp.. u must have power on the red and yellow wires.
Awesome thank you fellas! Let the soldering begin!
I also just realised the blue on Yamaha connector is deadened in connector anyways.
