Yamaha242lsdallas
- Fort Worth TX
- Limited S
OK, I have a set-up question for the best way to set my system up with current amps/speaker that I have.
Here is list of what I have.
2 amps:
Clarion XC6210 - 2 channel 85 Watts × 2 Continuous @ 4-Ohms
JL M400/4 - 4 channel 75 Watts X4 @ 4 Ohms (also have a remote wired fader for this amp if i want to use it)
Speakers:
6 Stock Polk 650 (4 in cabin and 2 on transom) - not sure the power handeling on these
2 JL tower MX770 - 70 W i think is what they are rated for
I want to be able to have the tower and transom speakers powered seperatly an to be able to fade that volume seperate from the 4 cabin speakers.
Oh, head unit is a Clarion CMD8 - 4 channel output.
What would be the best way to wire this up?
And before anyone says just pick up a 8 channel amp - I'm trying to do this without spending any more $. I would think i have enough to put some reasonably good power through the tower/transom speakers with what i have. I want to be able to hear behind the boat a little more then i can right now while wakesurfing. I know the MX770 do not put sound at a distance like a set of wetsounds will but I would think they still will do a 1/2 way decent job if powered right.
I'm a noob when it comes to doing sound so any help would be appreciated. Even the basics of wiring the power. speaking of, I plan on using 4 AWG (or should I go 2 AWE? Then 4 AWE from the block to the amps?) stranded wire straight from the battery to a distribution block then fusing each amp separately. Can the remote turn on be used for both amps at the same time coming out of the head unit?
Lost of questions I know, been looking up guides online but not seeing something that fits what I want to do.
Thanks in advance.
2 amps:
Speakers:
Thanks in advance.
