I can't see each light being fused, that's not feasible nor cost effective...the whole courtesy circuit, and/or navigation circuits too, but not a single light.also, would anyone know where the fuse is for this? ...just in case it’s a blown fuse
Looking forward to seeing the result of this...I have the same issue on my port side.One of my front white courtesy lights (side panel) Stopped working. Does anyone know how to access it so I can replace it? (The bulb plastic cover is flat and I don’t see any screws or a way to remove the cover.
Did you have any luck figuring this out? I looked at mine and didn’t see any screws either.I’ll check again this weekend but did not see screews anywhere on the panel. My boat is at a marina with my trailer stored somewhere else. Taking the boat to the dealer is a mission.
would be much easier to just replace the light bulb.
Not really, no screws anywhere. I may need to think about removing the speaker and see if I can reach the light bulb from thereLooking forward to seeing the result of this...I have the same issue on my port side.
Yeah, I looked at it again closely today (I think my speaker is blown), the only screws there are around the speaker.Not really, no screws anywhere. I may need to think about removing the speaker and see if I can reach the light bulb from there
That makes sense, thanks. I tried to pull it out with my fingernail today, but it didn’t budge and I don’t want to force it. What is the best way to pull it without damaging it?The face of the light is a cover that needs to be popped off to see the 4 screws
Jim, looks like we have the same issue lol. I have my boat at the marina, will try to pry the light cover opened as suggested, but honestly don’t see how to. I also agree these LEDs should last a long time, so I’m worried it could be a wiring issue. Please let me know fo you find a way to get to the lightbulb, I‘ll do the same.That makes sense, thanks. I tried to pull it out with my fingernail today, but it didn’t budge and I don’t want to force it. What is the best way to pull it without damaging it?
LEDs should last forever (practically), do you think wiring or something else could be the source of the problem since these are newer boats?
TIA.
Yup, this. I installed these same lights on my old boat. Was interesting to look up at them and realize they're the same. Mine had a TINY slot you have to poke around and see at the edge. From there you can get a small flat-head screwdriver in to pop off the cover. Then you'll have 4 small Philips head screws.The face of the light is a cover that needs to be popped off to see the 4 screws
Thanks! So you installed this part: Yamaha F2D-U8124-10-00 - LIGHT, ROOM 1 | Partzilla.com ?Yup, this. I installed these same lights on my old boat. Was interesting to look up at them and realize they're the same. Mine had a TINY slot you have to poke around and see at the edge. From there you can get a small flat-head screwdriver in to pop off the cover. Then you'll have 4 small Philips head screws.
I'm fairly certain due to the light output and color that these are in fact LEDs.
Looks like this part. Oddly enough I have one out in my 2020 212x. It was probably out from day 1, I just never turn on the lights. LOL! It's $50 for a new one, and worth my time not to deal with the dealer for warranty stuff. So I'll likely pick one up in the off season.2019 ar240..starboard bow courtesy light out.
mine have no screws..just pressed in..pried out.
didn't see them on parts breakdown at sportsplaza.
ordered some screw-ins from amazon...will post when finished
