LethFT
- Tampa, FL
- SX
Hey All,
Was out last week and right when we were pulling up to retrieve the port pump started making noise. Thinking I had sucked something up and was getting cavitation I pulled the boat out and finished our day. Nothing in the plugs so I got underneath and nothing in the intake grate either. It looked as if the impeller was rubbing up against the wear ring. Ok guess its time to replace the impeller housing (was planning to do this winter anyway). Begin pump diassembly and its not coming out. Started pulling and that's when things got interesting. The pump pulled away from the impeller and housing and then would go no further. Pulled bolts for housing and it would still not come out. So I pulled the cone and found the root cause of the issue. Water inlet into pump bearings causing catastrophic failure. Pulled the nut and was able to get the pump and impeller housing off but the impeller is still not moving.
Does anyone have any suggestions for getting this impeller out with damaging anything else? Pictures of the carnage included. Thanks in advance.
