AZ_AR195
- AR195
Hey everyone - So as stated above my family and i had an occurrence on the lake last weekend. After changing my shorts from this near swamping i started thinking about redundancy systems especially for the bilge pump and electrical.
Here's the story;
As read in other posts i know the boat is compartmentalized with plugs in the ski locker, engine compartment and rear drain plugs. I always boat with all plugs closed while in the water and open all plugs once out of the water as recommended by yamaha. during my "occurrence" water filled the anchor locker and ski locker ( they are 1 continuous cavity ) then through open seams under the floor, water filled the gas tank compartment. The bow was about 4" above water line and the stern was pretty much close to being fully out of the water. Long story short the bilge was overwhelmed but with our bucket brigade helping, we saved the boat with no damage ( except to ego and 1 cell phone ).
so here's my thought - please give your opinions;
I believe the stock Bilge pump is an automatically activated 1000gph pump - So Should i add a second pump of equal size in the ski locker and plumb the egress port into the existing line or make the second pump independent utilizing a flexible hose that can be thrown over the gunnel if use is needed. The independent option would utilize a larger pump, say a 2500gph pump. 3rd option is to upgrade the current pump to say a 4000gph to really move some water if needed. Bilge pumps are cheap, boats are not.
Battery protection - From factory the battery is exposed - adding a quality water tight battery box to prevent shorting thus allowing pumps to run as long as they possibly can.
Obviously avoiding being stuffed like a turkey is the best option but the lakes here in AZ get suuuuper busy in summer and the power boats love to zip by us tiny bow riders. So im thinking better safe than sinking! Thanks folks!
Here's the story;
