Subwoofer in bow of 242?
F.M.
Decatur, AL
255XD
First off, not my actual boat, I found this image in the media section since it's raining and I can't take an actual photo. I'm looking at adding a 3rd subwoofer and I'd like to put it in the bow area. But I don't want to take up space under the bow seats. Does anyone have any idea how much space is free in the area behind the step up pictured here?
I am not sure on exact measurement but I looked into this at first then realized the anchor locker is completely enclosed making that a tight space. So I quickly looked elsewhere.
I have one above the step in my 2013 212x. I don't have that back rest though obviously.subs2.jpg
As soon as my honey do list is finished tomorrow, I'm going to climb in and take some measurements.
Nice! Did i miss a thread on this somewhere?
Unfortunately not. It was actually done by the previous owner, so I just get the benefits. ?
Finally had time to try to get some measurements. There is only one way to get to the back side of that step without cutting a hole, through the ski locker. I wedged my fat butt into the locker and could see behind the step, but couldn't maneuver enough in there to use a tape measure. I would say there is about 7-7.5 inches of room behind that step up. Plenty enough for a shallow mount sub. The only issue is the slight curve to the front of the step, but that can be fixed with some hdpe, a cardboard template and a router.
@Drift Away and @wallacerb did a double JL M770s install here in that spot, it's posted somewhere here. Hope they will chime in, they had pictures and posted the exact measurments.
I've seen that thread. Those are in the anchor locker, and look really nice. I have a backrest there though. I'm going to put something below the step.
I would be curious to know how bad the anchor and chain rattle in that location with a sub.
Mine shouldn't rattle at all. My anchor locker is lined with a few layers of 1/2 foam.
Slightly off topic, but... depending on boat loading the anchor locker drain can sometimes sit under water line.
Which discouraged me from installing any permanent padding there, I just throw a couple pieces of gym mat at the bottom. Which is okay but not great.
Wonder how does your foam padding hold up - if you posted on it somewhere else?
1 season with it so far and it is holding up great.
