Subwoofer location?
Xixp
Boatless
I would like to install a 10” IB Sub in my 2017 AR210; i was thinking behind the helm seat but both sides of the bench seat base are not flat.
where others have placed it?
Tia!
That is a tough one. I don't know if there really is a spot.
My rear seating is the same with curved surfaces. How about the lower section under the port bench? If I were to install a sub, that's where I'd put one. My boat has a bucket seat on the port side but the lower section should be roughly the same near where your feet rest:
Tia!
I've seen them mounted under the bench on the port side. Here's one from a 210.
Thanks to all..i ended installing it under the bench seat, i added a 3/4” PVC board at the back to reinforce the area. I used bolts and nuts to sandwich the fiberglass wall between the sub and the pvc board.
How do you like it? And you went, sub->fiberglass boat wall->pvc board, is that correct? The back of the sub cleared the outer hull i'm guessing on the backend? Asking, because, if I install a sub this is where I planned to do it.
yes, that what i did . There is a lot of room behind the sub (between inner wall where sub is mounted and external hull). Sound is very good as well , the boat free space behind the sub acts like an enclosure…
