Jim Davis
- DFW
- 255XE
I sucked up a small stick that got wedged in the impeller. When it happened I was pulling a tube at about 20mph and it made a horrible sound with a little bit of smoke coming from somewhere. The riders could see it. I was able to get the stick out but it still isn't working right. Sounds like the engine is running fine but the jet pump sounds like it is slipping. I was running it on the trailer after removing the stick on a hose not in the water. I haven't pulled the pump yet but wondering if you guys have any idea what it might be and how hard it will be to fix. Splines on the shaft maybe?
Also I noticed that on the starboard intake it is a smooth transition from the grate to the wear ring but on the port there is like a ledge where the grate stops and the wear ring or whatever part that is before it begins. Is that normal on 2019 242xe or did i get a bad or incorrect intake grate? Was too dark to get a Picture.
Thanks
Thanks
