wango tango
- michigan
- Scarab
- HO Impulse
is it true that rotax supercharger loses performance in warm water and weather ???
I forget, do all the supercharged rotax require premium or just midgrade? If super hot out i would consider premium to combat some of the heat.On worse case conditions yes you could see a up to 400rpm drop, but that would be caused by
Lake temperature above 85F
Engine compartment temperature above 110F
Poor gasoline quality or low octane.
The colder the intake charge (engine compartment + Intercooler) the better.
The Rotax engine have build in sensors (Air intake temp, Knock, ...) that will do what it takes to protect the engine.
