ssully
- Scarab
- 215 ID
Any feedback on optimal set up for the 2019 Scarab 215ID with wake plates? How do you run your ballast? Do you run both wake plates or only on one side, if one side, which one? The one with the surfer or the other? What types of speeds are you having success with? Are you putting any ballast in the very front of the boat? Thank you!
