svho intercoolet with 2 dedicated pisser lines
Jester429
not sure if anyone else has noticed but I did an svho intercooler upgrade on my '14 ar192 with the 2 dedicated pissers. one has hot water coming out of it... one is lake temperature... im a little perplexed. any thoughts? thanks
jester
do you have any pictures of your setup? That does seem odd
yes very strange. did you just do a dedicated line to the stock intercooloer or did you put an aftermarket on like a riva or fizzle? i cant remember how the stock plumbing went but off my fizzle its the same water, just split to 2 lines. there are usually 3 pissers. 2 are intercooler and the other one is off the oil cooler so i could definitely see a difference between oil and intercooler.
its the bigger intercooler off a jetski. pretty sure I figured out the problem but I dont want to admit it lol it was quite evident when I went out and looked once the boat was on the trailer that I should have had 3 streams of water.... not 2... (2 intercooler and one oil cooler) i had zip tied the hoses together under the deck and pinched one off accidently and I think some marine vegetation plugged it up so no flow....
Glad you got it figured out
