TheGriz
- SX
So, I have a 2007 SX230HO. I was vacationing up at my cabin in the straits of Mackinac (Northern Michigan) when my anchor chain broke. My boat washed ashore in 1-3 ft waves, leaving the engines and batteries underwater for about 4 hours until I was able to right the boat and start to drain the water. While making a call for help, my neighbor started the engines while completely submerged (my wife snapped into action quickly, making him cut them off).
Here come some things I've done:
1. First thing I did was pull the plugs and turn over the engines. Lots of water and milky oil were ejected. The rotating assembly sounds good and no bad noises indicating hydrolock or broken rods, etc.
2. Changed the oil and plugs
3. Fired both engines. Both engines started and ran. I put in approx the same amount of oil that I removed, but when the engines were running, foamy, chocolate oil rose up into the airbox. I didn't catch it in time, and the starboard engine stalled out before I knew it was filling the airbox up.
4. Changed oil again (still very milky). Changed filter and plugs again. Starboard engine will not run now. It runs for about 5-10 seconds and stops.
I've now changed the oil 3 times per engine and still have the chcolate water/oil mixture.
Questions:
1. Is there a better way to remove engine oil than with a pump? I feel like I am only evacuating 2/3 of the oil. and I just keep getting the same result, with water down in the bottom of the engine never being removed.
2. Any ideas about the starboard engine that now doesn't run? I pulled the plugs again and nothing is hydrolocked. Best guess from me, is that I sucked in oil instead of air and the injectors aren't happy.
3. Why does the oil keep overflowing into the airbox? Am I overfilling?
Thanks in advance for the help, I'm about at the end of my rope. I still haven't started to fix the damage to the reverse gate linkage or thrust vectors.
![zSWCPdc.jpg](http://i.imgur.com/zSWCPdc.jpg)
![xF7u6Rj.jpg](http://i.imgur.com/xF7u6Rj.jpg)
Questions:
