Swim Deck Radio
Drift Away
So i have replaced my swim deck radio 3 times now. But this time i did not put it back in the same spot. Its a little tight and ill have to trim the rubber cover (i almost never use it anyway) but this is the best spot i could find to keep it out of the water.
20190322_113105.jpg20190322_113113.jpg20190322_121633.jpg20190418_124244.jpg20190418_124720.jpg20190418_125019.jpg
Where did you find the replacement radio at?
Nice job. Good idea with the table mount.
Now that's clever
Looks Good
I always thought it should be mounted higher!
Yeah, that's pretty solid right there.
I though they would not cover that radio? How did you get them to cover it? Think mine is about to go.
When i took it in for service they reached out and for some reason they covered it again.
Aloha @Drift Away that’s a very smart setup and mod. I will be duplicating this for sure. I just gotta get Yamaha to warranty the radio first, if not I’ll need to replace myself. Just wish we could upgrade it to a better unit.
View attachment 92100View attachment 92101View attachment 92103View attachment 92104View attachment 92105View attachment 92106
Man, that looks good. I’ve been meaning to do this forever, how does the table mount fit? Any issues? Just bought a new part, correct?
Love it!!
Was there a need to rewire the remote or did you have enough slack on the factory wire?
Love it!!
The table leg covers the hole. But i did have to put a piece aluminum at the bottom behind it with 2 holes. The top holes are into the boat the bottom is thru the plate. Nothing to rewire. Its just a S video looking cable that plugs right in. They gave me a whole new radio. What we see on the swim deck is just the remote. The brain is under the dash up front. I did not change that out so all my presets, bluetooth ect are saved.
@Drift Away where did you get the extra table leg mount from?
Prefect
Thanks
I am not 100% sure our table legs will fit. Ill be back in FL 9 may and i can let you know for sure. I have never used my table on the swim deck it just sounded like a good way to cover up the whole.
While I was adding that item to my “boat list” on amazon, I also saw the whole kit with mount, leg, and table top. With the kids, I’ve always thought it would be handy to have a 2nd table located in the bow.
Do you think a couple strips of aluminum or star board would be enough to reinforce the bow storage compartment, or the front of the anchor locker for a table mount and table??
Hahaha thanks
I will wait until you try it before I order one.
I want to put a mount in the bow of the boat so I can grill in the bow if I wanted to
Do you cover your remote on the swim deck with that rubber like cover that came with the boat?
