Switch circuit breaker replacement
Ibeflyinhigh
Is the circuit breaker built into each switch or a separate piece? Has anybody ever replaced one on a newer yami? I need a higher amp breaker installed for courtesy light switch. Any help would be apprecResized_20210712_195437.jpegiated.
If your running a higher light load I would leave the switch setup you have and add a relay of appropriate size and fusing to take the heavier load. This would keep the clean look of your switches while properly controlling the load.
