Scott - Hilton Head
- SX
I had my 2013 Yamaha SX-210 in for service and the repair center (Authorized) did a water test after work was completed. They said the intake water passages were clogged causing the engines to overheat quickly. The repair center has given me a quote for $3200 to remove both engines, remove exhaust heads and clean each passage by drilling out each passage (carefully) and then flushing remainder to clear - then reassembling. Other option they say is to replace both engines at $10K per engine plus 8 hours labor. Clearly not an option for me?!?! Is there an easy way to clear these passages or remove built up sand/salt myself? If not, is this estimate reasonable or should I have work completed elsewhere? Thanks very much.
