SX 230 Cleaning Supplies
YamahaziPilot
I want to clean the bilge and wax my boat and am curious what you guys are using on your Yamaha boats?
You might want to use the Search function, and then you could ask a more specific question.
I cannot help with the bilge; I have never needed to clean mine. The boat's bilge stays dry.
You can skip the anti-salt portion if you boat in fresh water.
FWIW - this is what I do:
After I come back in, the boat is moved from the water to the wash rack by the forklift. I then spray down the interior (including the clean out port and plug) and hull with Salt Off (West Marine's version of Salt Away) using a garden mixer on the end of the hose. I do not think the maximum mix rate is equal to the mix rate in the flushing unit, but it is enough to remove the salt from the interior and exterior. After I spray it down, I flush the engine with Salt Off for about 5 minutes. During the engine flush, the Salt Off solution is working on the interior and exterior of the boat. During the engine flush, I usually but not always get a weak stream out of the pisser. I am flushing the engine within 15 minutes of coming out of the water, so it is still hot.
After I finish flushing the engine, I wash the boat with a good quality wax and wax soap (Griot's or Meguiars) using a soft blue bush on a handle. I then rinse and dry the boat; I dry it with a few microfiber towels (inside and out not including the non-skid floors).
I do not use the Yamaha silicone spray. Instead, I use Corrosion-X on the engine and electrical components in the engine bay, the electrical connections behind the curtain inside the console and all hose clamps. I spray all of these down each year - just once a year. When I had my annual service in April, the Yamaha Tech told my salesman that my engine was the best looking 2.5+ year old engine he has seen.
If I see any hint of rust on any of the hardware (for example a screw head), I spray it with The Must For Rust. I just leave it. It removes any rust and leaves a protective coating.
I polish and wax the boat's hull once a year with Griot's One Step (a synthetic paint sealant and polish all in one). I pick a day that has little activity at the marina, so I can keep it on one of the 15 wash racks for as long as I need. I apply the Griot's with a random orbital buffer using a medium cut pad (to remove the old wax, water spots and any minor blemishes). I wax the interior surfaces (not including the non-skid) by hand with Griot's Poly Wax (synthetic paint sealant). I clean and protect the vinyl 4 times a year, and I use Non-skid wax on the non-skid twice a year (warning - it does make it a little slippery for a week or two). I also use metal polish on the rub rail, wheel and etc. once a year. Finally, I polish and wax the windshield every year.
The boat looks new.
The Griot's lasts for a year without refreshes or detailer. The boat is stored in a partially roofed open rack.
This is after one year.
This is just polished/waxed.
The boat looks new.
This is perfect. I really needed to get down to the nitty grity because this is my first jet boat and before it I had bass boat so they are two different beasts. Thanks again.
I use Collinite cleaner and wax combo. Based on my experience, I got better results when I used both products of the combo pack in working on the restoration of my boat. Using the product was easy because all I had to do was apply a small amount on my machine polisher and re-apply the product as needed.
Easy, peasy. We cleaned it up with the Meguiars M6332 1 step compunction and then used this wax with a micro cloth bonnet on a polishing wheel. It looked and felt terrific.
Work in 2-3ft square sections. Polish, use 1 rag to remove excess (the" wet rag"), then 1 rag to buff the haze (the "dry rag). This worked really well.
