Wake Turbulence
- Zachary, LA
- SX
I installed Polks to replace the crappy OEM speakers in the SX190.... a few things that made it not as simple as I expected...
1) The spade connectors are different size and the Polks was smaller... instead of replacing them on the boat side, I just crushed them with pliers and got a solid connection
2) The hole pattern isn't the same, so be prepared to drill new holes in your boat
add the remote volume control unit on the driver side. That is a must...relying on someone else to get in and out of the glove compartment to adjust volume is the blues.
Very happy with the stereo upgrade so far. A new Kenwood head unit which has Bluetooth. And a small but sufficient amp for our music. A Pyle 400 watt amp. Next up will be speakers! I plan on ordering the Polk 6.5's from Amazon, anyone had success with those?
Were those better than the ones that come with the boatNew speakers installed, look and sound great!
View attachment 58468 View attachment 58469 View attachment 58470
How did you get the stock speakers out. I have the Marine Audio speakers and can't figure it outNew speakers installed, look and sound great!
The grills pop right off, then you will need to pull the screws.How did you get the stock speakers out. I have the Marine Audio speakers and can't figure it out
