Luke Lapham
- SX
ok, so I was under the impression the motor compartment was separated from the bilge other then by a drain plug... and also thought that the water like rain would Chanel through the platform and drain out the back of the boat without entering the bilge...
This brings me to my story, I pulled my boat off the lift and tied it to the dock .. not 45 min later a Florida storm hit and it started to pour.. it rained on the boat for about 1/2 hour and I downed my raincoat and went out and pulled it back into the lift. After I pulled it out of the water I fired the motor up and flushed it... I lifted the motor compartment to find that it was halfway full of rainwater!... I turned off the motor and engaged the bulge pump. I went to the rear of the boat and pulled he drain plugs.. no water came out... the ski locker was also full of water as well. I noticed my lift is a little off level and just a tad bit of pooling in the front of the boat when I wash it... can someone explain the physics of the drain system so I know what to do... as of now the ski locker still has 2" of water in it that will not drain and I pulled the plug in the motor compartment which drained the majority, but not that last little bit...kinda concerned since I got ride of a Seadoo Utopia that all water drained to the bilge in the boat and it was a terrible design and a non carful person could "lift sink" their boat if the battery was dead and they didn't pull their drain plugs...
