Sxrmike420
- SX
Every time we go boating and I pull my 2006 SX210 out of the water it drains about a gallon of water from the drain plug. Any idea where to start to figure out why. And on that same note, should I have all of my internal drain plugs left open or should they always be closed? Obviously the main drain should be closed when boating but the "cooler" plug and the 3 inside the engine hatch I have been leaving them open with the thought that if there is any water it will allow it to flow to the rear of the boat so it can drain when I pull it out. Is this right?
Is there a way to make sure I don't have water trapped inside somewhere? I go boating on the river so my boat gets very sandy and Im just wondering what if there is a blockage of sand under the floor somewhere? Should I remove the large floor piece to check? I'm just not sure how the drain system works and I towed my boat home this week to clean it up and whatnot so Id like to give everything a good once-over while I'm at it.
Thanks for any and all help and advice!
