Mshook1221
- SX
I have a 05 sx230 and the one motor will not run unless you hold the key in start position how to trouble shoot or bypass to run
I had this exact issue on my 06 sx230. I found water in a connector in the aft, starboard access panel located in the storage compartment. It's the round, white panel with about 6 screws in it. Remove it to access the wire bundle. The connector you want will be labeled port or starboard depending on which engine you're having trouble with. I just took each connector apart, one at a time, inspected them, dried them if wet and put them back together.I have a 05 sx230 and the one motor will not run unless you hold the key in start position how to trouble shoot or bypass to run
No it’s not it follows the harness for that motorSwap key switches to see if it’s the switch or not
I will try that thank youI had this exact issue on my 06 sx230. I found water in a connector in the aft, starboard access panel located in the storage compartment. It's the round, white panel with about 6 screws in it. Remove it to access the wire bundle. The connector you want will be labeled port or starboard depending on which engine you're having trouble with. I just took each connector apart, one at a time, inspected them, dried them if wet and put them back together.
We've had a few members report that problem, some have put a layer of silicone or tape over the top of the box to try to help seal it,Has anyone had a water / condensation issue in the electrical box in the engine compartment. Mine was holding quite a bit of moisture so that it got the ecu wet. I was thinking of drilling 2 weep holes in th bottom of the boxes to allow water to weep out and keeping from the ecu getting wet again. Suggestions or similar ideas ?
