shore
- SX
Boat showed no overheat alarm or lights when ran. I saw outside ports shooting water at speed. I simply noticed steam from the port side when flushing and saw no water from exhaust.
The issue is the port engine on the hose, it does not flush water out the exhaust or the thermostat discharge port in the tunnel(white fitting). These are the large exits in the tunnel. SB engine just flows away out of both large exits.
I've pulled the red hose off the Y-fitting and it flows water albeit a LOT less than what is coming out of the flush attachment on the garden hose. I ran a screwdriver through the y-fitting and it's clear. I've gone further up the line to the oil cooler water line and when I turn on the water, it doesn't burp it out. The water is there but doesn't come out. I pulled that T-fitting off underneath it and it was completely clean.
I also pulled the thermostat and it was open, engine was warm.
