RRaack
- SX
Finally had a chance to adjust and slightly slow down the port side idle so the no wake mode would engage. Also adjusted the throttle tension. Anyway, while I'm tinkering I thought I'd ask you guys. Ever since we bought the SX, both outside tach lights (engine and maybe oil if I remember) just barely light up. You don't really even notice it in the sun. I just happened to be under the cover while working on her yesterday and noticed them again. They light up brightly and flash when in no wake mode, but return to faintly lighting up when disengaged. I had the port ECU burn up and rebuilt several years ago and all injectors cleaned and flow matched. However, I think the lights were doing that before then. Oil levels are fine and recently changed. Never had any low oil or overheating or anything. Seems to run perfectly. Any ideas why these lights might be illuminating? I may pull the dash and swap the tach and see if the issue follows. You know, (thinking out loud) I think they might be doing this even when the engine is off... gotta be a short in the gauge...I'll check again soon... Just want to make sure it's not something wrong.
