J-RAD
- Orem Utah
Every outing in my '16 AR240 I end up with copious amounts of water in the bilge. Gradually I've been able to find and seal a few I've found along the way, but the water persists to infiltrate somewhere...?
To date, I found the drain line detached from the rear clean out tray. A leaking check valve on my ballast overflow sending water out the bilge pump. Besides that I've only been able to find a couple dribbles... Nothing that can justify the amount of water I'm seeing.
I've pursued the leaks a little harder this season, actually did a reverse leak test by raising the bow on the trailer and filling the bilge with water. Filed it up to the bottom of the drive shafts and nothing...
Boat is stored sheltered from the elements.
I'm tired of leaking in public, so where them leaks at?
