JetboatBrad
- 242 Limited S E-Series
Hello all,
I was hoping some of you fine gentlemen may be able to help me. I recently put in a new port side engine in my 18 yam 242 LSE. It was a takeout with only 18 hours on it. I finally got it in and running and everything seems to be good. I believe I have the couplers pretty much aligned. Pulled it apart and adjusted like 3 times but it seems like I had to still slightly lift the final time still but much at all. When I feel it now it’s perfectly even and flush.
Now I have been noticing my automatic bilge turning on and even occasionally to the red. There are 3 modes on this factory bilge: green is on and monitoring, blue is when it’s working and red is for high water level. I have had it come on in the past but there is definitely more water getting in now. It seems like the new engine has got a slight bit more of rough vibration than the other one. From the sound, it almost sounds like the impeller is flopping around in there a little more.
It has always seemed to have gotten some water in through the swim platform when I would get the wake hitting me while stopping at low speeds, especially when someone is sitting back there.
I have felt back in the back of the firewall where the impeller goes through and it felt dry from what I can tell. It seems to get worse at high speeds/RPM’s. I’ve let it sit overnight and doesn’t seem to be taking on any at stand still. You guys have any ideas? Or where you guys would start?
I appreciate any thoughts or ideas
