David Martin
- Punta Gorda
- SX
Did not want to highjack another thread that mention anodes on a different problem. My SX240 2013 was purchased inland (fresh water) I live in Florida salt water and keep reading that zinc should be used in salt.... not sure what I have(any online parts houses you guys recommend for zinc on Yamaha.
Last question on Tank vent next to fuel fill..... Trying to understand a closed vent system that requires a hex wrench to open. I first thought opening vent during fuel fill would result in an easer fill(less pump kick offs) but that has not been the case. My last few fills have been vent closed, and the tank would take it as fast as the pump would go as long as I has the nozzle in the filler hole was correct. So I no longer open vent with hex key.
Thanks in advance guys
