COtoFLsurf
- Key Largo, FL
- Limited S
Been reading the posts on-board battery chargers, and debating between a single or dual-bank charger for my 2015 242LS.
Currently, I connect my portable charger to the starter battery, and once that battery is topped-off the Relay closes and starts charging my house battery. This seems to work great and charges both batteries without having to move the charger connections.
If I used a dual-bank charger, the charger would initially sense and charge each battery independently. However, once the starter battery was topped-off the Relay would close and both "charger banks" would be charging the house battery.
What happens if both banks of a dual-bank charger are connected to the same battery? Am I thinking about this correctly? If so, does this defeat the purpose of a dual-bank charger?
