Leadfooty
- Limited S
Finally installed my JBP SeaDek and it turned out exactly how I hoped it would. JBP's products are extremely well tailored for these boats. The only criticism is that the pad-gap on the storage hatches is larger that for some of the other adjacent pads. I might've been able to do it more consistently had I measured the gap for the hatches then tried to match it in other areas, but it still would've been inconsistent in some areas.
Some install observations:
The only piece that didn't fit spot-on is the pad at the front of the pilot seat. To get it to match the curve of the storage hatch, I had to install the pad right up against the pad that goes under the seat. Not awful, but the rest of the pads are spaced 1/4" or more apart. But as others have said this is why you need to install the pad under the seat first. Otherwise you won't be able to get it centered around the seat-post.
The get the triangular pads in the front of the boat to look mirrored, they needed to be installed by eye, as the two sides of the boat are not the exact same size.
Starting at the bow and carefully aligning the center grove to the center of the boat made it easy to keep all the pads dead-straight. I used a metal ruler to ensure the lines all...aligned. I REALLY like the way it all looks now, I think it's worth taking the time to get it right.
Kudos to JBP on a great product.
