The Subaru is now a tow rig
zipper
Jetboaters Fleet Admiral 1*
Staff member
Administrator
Northern Vermont Lake Champlain
Boston Whaler
I just installed a Curt reciever hitch on the wife's 2013 Subaru Outback this morning. I also installed the trailer light wiring plug kit. She wanted to be able to tow the 14' O'Day Javelin/trailer to the ramps instead of always using the truck. Makes sense, it is a light and short package easily done with her car. She is already looking for accessories that will mount to the reciever.
@zipper Welcome to the club! LOL. I’m also using my 2016 Outback as a tow rig for my 18ft sea doo. I wish they had a more “beefy” engine.. and something other than a CVT transmission. But their all wheel drive system is the absolute best.41E704AF-FF9E-4124-8DF2-0039AF55B07A.jpeg
I installed a hitch on a customers Subaru many years ago, but I don’t recall whether or not I had to run the wiring. Some of these newer vehicles are really fun to run wires on, did yours fight you much?
Since we put a hitch on the Prius our jetski usage has Increased dramatically. Getting 35mpg while is not bad either ....
No, it was pretty much "plug n play". Finding the socket behind the interior trim was the hardest part. Once found near the drivers side rear wheel well, it was easy. This one unfurls to the trailer connection from the inside of the car and gets closed in the rear hatch. The pigtail is not permanetly outside, like a truck. About 20 mins to install. The hitch was about 90 mins. Used the "fishwire" method, per the instructions, to install the bolts and washers. It worked well.
So you didn't have to string anything over to the passenger side? That's usually what makes things fun, and most vehicles don't have the passenger side turn/brake light wiring in the harness on the driver side. Some even require a 12v supply wire to be strung up to the battery/fused link under the hood.
No, plugged into socket, mounted a ground wire. All lights, directionals work.
