Nous Defions
- SX
I have read some where that: Each engine on the 240 has a rectifier regulator that limits maximum output voltage to 13 volts between 2000-3500 rpm's, with a stator coil output voltage of 8.3v cranking, 36.4v@2000rpm, and 64.7v@3500rpm.
Another site says there are 40 amp magnetos on each engine.
If it's correct that each engine has a 40 Amp charging system does that mean the total amps possible for a charge is 80 amps?
Any electrical guru's out there that can clarify volts vs. amps vs total?
