There are TWO changes to EVERY boat in the 2017 line up! And one other change...
Julian
Jetboaters Fleet Admiral 2*
Staff member
Administrator
Raleigh, NC 27614
242X E-Series
As I hinted in the 2017 new boats thread, there are 2 changes to every boat in the line up, and one change to the deluxe models in the line up.
The first change will be a welcome one for many of you....a NEW CLEAN OUT PLUG DESIGN! Yes, they've finally changed the plug to a design that cannot blow out (unless you don't install it properly). It has fixed dogs and twists into place. If the handle isn't parallel to hatch lines it isn't locked -unlocked, the handle is at a 45 degree angle, when twisted and locked it is at a 90 degree angle from the bow/stern line. This is REALLY easy to tell!
My only concern with this new design is what happens if you don't keep your plugs clean? I asked Yamaha about this and they said they tested it and that it is designed to be easy to twist out. I'm not convinced, and can forsee a plug twisting device in someone's future! LOL Something like a water shut off valve big T handle. Their comment...lube them and keep them clean and remove them between outings and you'll be fine.
Delighted they finally made this change!!!!!
The second change is they moved the engine flush ports to the swim deck. Now this change I'm not so sure is a good idea. You are typically in the cockpit when you are flushing...this will force you to go to the stern to turn on the water after you start the engines. Not a big deal....but less easy. It will mean that if your ports aren't closed properly....the water will just run off the swim deck. I'm also wondering how this will be when doing oil changes (for those of us that do them ourselves). Time will tell on this change. You can see the flush ports in this photo:
The last change is to all the deluxe models...they now have snap in Seamat (think Seadek) in all the cockpit areas. This seamat is very thick and although I didn't measure it, seemed thicker than Seadek brand. They made it snap in so that you could still easily clean the boat, and if a piece gets damaged, you can just order new parts and snap it in with no glue and no fuss. They said they were trying to get this done for last year....just a year too late for me and my 242X! This is a nice touch!!!
Two out of three ain't bad... Removable sea mat sounds like it would have been nicer to have than the Seadek I just put in, twist plugs is only slightly positive - you're right, if they're seized what do you do? And put me down for a 'fail' for the new flush port location. Looks like a PITA to access.
I like that seamat! The new cleanout plugs are pretty slick. What keeps them from rattling loose?
So no changes to the 240 series other then clean out plug and moved flush port correct?
And the deluxe levels get removable Seamat in the cabin. (and some new color schemes)
Sounds good that means I can keep looking for a left over 16 the color combos are nice
Was hoping that the 2 new in every boat was going to be twin TR1's, not cleanout plugs and flush ports :(
All great updates so very positive.
@Julian did the add seadeck to the ar240? Still makes no sense to me the sx240 came with seadeck last year and not the ar240
You wouldn't want twin TR1s in the 24' boats.....
I did ask them why they haven't put 2 big pumps and twin 250's in a 24' boat to make a 60mph monster, and their reply was that there wasn't a market for a boat that fast and that expensive......I think it would sell for those that love speed....but can see their point to some degree. I also think the attorneys get in the way of some of their choices. When they build the whole boat, it is up to them to ensure it is safe. If someone take two 300hp outboards and sticks them on a small boat....not their fault....
OK...they didn't clarify with me which models specifically woulds have removable Seamat.....I wasn't aware that the SX240 has Seadek in it....are you sure that wasn't an dealer add on?
Yamaha site has the SX240 with:
Snap-in Soft Marine-grade Carpet
Anybody know if the new seamat will fit in a 16 sx240? Mine has the snap in carpet
Sorry should have clarified the sx240 comes stock with sea deck instead of hydroturf on the swim deck and anchor locker the AR240 was still using hydro turf for some reason. Both came with interior carpet correct. If the pics of the 2017 are accurate to stock it appears they may have changed it this year.
I asked that and it will fit, but it will NOT line up with your carpeting snaps....you would have to move and/or put in new snaps. I asked that question specifically for my boat..... :-(
@robert843 Seadek was just for swim platform in my ar240 (2016)
I'm so glad I pulled the trigger when I did.
EDIT: Seadek also on top of anchor locker and the little step.
Your 16 came stock with sea deck? Maybe they changed last year and I missed it
Weather you like the new features or not, it is ultra cool that Yamaha is listening to its user base (us) and improving their boats. Keep suggesting things guys!!
Yes, but its only on the swim platform. I actually like it that way.
Not sure what to think about those removable Seamats... I dry slip, removing those to get them washed and dried would seem a lot more difficult than dealing with carpet. If anything, I would go with seadek throughout, but will stick with carpet for now.
The removable seamat is just like seadek. They only decided to make it removable so you could easily replace it if it were damaged....and clean it easier IF you wanted to. I suspect most would just leave it in and hose it off--rarely removing it.
