ChrisM
Jetboaters Commander
- Rock HIll, SC 29730
- Chaparral
- VR
Inquiring of anyone that has this product in use to give your feedback.
I'm wanting to add some of these to my Vortex. I have 10 factory cup holders, the data sheet shows these units are in-line fused with a 5 amp fuse, and their power consumption is 3.1 amps. That's a lot, especially when you start adding multiples. They do have low voltage shut down technology (10.5 volts or below), and a high limit ambient/semiconductor cut off 150f or higher. You're required to add your own inline power interrupt switch, and/or wire as desired such as zoning. I would prefer to wire each unit I install off a branch circuit, with a local power switch next to or near the unit, combined with a master "zone", or master "all" power disconnect on the helm using one of the avail accessory rockers supplied on the starboard side of the dash panel. They are priced at $179.00 at a few retailers. There are videos, and data/info downloads 1/3 down on the Dometic site link. It's garnered very good reviews, but it appears only 1 or 2 seem to be installed per user, and typically on fishing boats where power consumption might be less opposed to boats with sound systems, and appliances.
http://www.dometic.com/USA/MS-11346...04-Eskimo-Cup-Thermoelectric-CupBottle-Holder
http://www.iboats.com/Eskimo-Cup-Cooler-Dometic/dm/view_id.1416472
