Thoughts...
Geiger41
Egg Harbor Township NJ
Boatless
NA
NA
May be able to get my hands on a 2018 SX195. LESS THEN 30 HOURS, excellent condition. For 25k..... Trailer included..... Thoughts ?
Inspect it closely and insist on a water test to confirm it runs well. I put more hours on my new boat the first summer and now it's at 201 hours...a 5 year old boat should have a lot more use than that, even if they like to float a lot. Just be aware that low hours could mean issues or left to sit and rust. Or it could simply be a good deal.
Also comes with a brand new monster tower that hasn't been put on......
Research the reason it was not put on. There may be plenty of them, but unless you need the tower, or want it, put zero value on that tower.
When installed correctly, they can be a good tower of course. But installed incorrectly could be downright dangerous. (but seems like a good deal on the SX195 by itself)
Based on the amount of hours, I am thinking this owner was just too busy.
Very interested in the follow-up here. Usually when something seems too good to be true... it is.
Could have a replaced connext screen which would restart the hours. You might want to hook it up to a computer and check the hours.
The Connext is just a display, it doesn't record any data that I'm aware of. The engine hours are read from the ECU which records the hours and error codes. If you replaced the screen, it should still show the correct hours. Changing an ECU would change the hours though.
Changing the connext screen does reset the hours, seems that dealers can update that.
When I changed my screen I think it showed the hours originally, then at some point I noticed it had restarted. I know that sounds weird but I remember looking at it and thinking oh great the hours are still there until they weren’t.
