djtech2k
- WV
- SX
I realize that these may be very basic questions, so I will apologize in advance.
I have a question about the throttle. On my 2012 SX210, there seem to be 2 what I would call neutral positions. The more forward one of them does seem to have some thrust in the back because I can see a tiny bit of water disturbance. The position that is more towards reverse, seems to have nothing. The 2 positions a quite a ways apart.
IDK if that makes sense or not, but is this expected? I mean I know there is the no wake mode so IDK if it has anything to do with it or not. Is this normal or is there an adjustment needed?
On another topic that IDK if its related or not, when I installed the cobrajet fins I sent pictures to Jeff to see if it looked right. He mentioned that unrelated to the fins, one of my reverse buckets looked slightly lower than the other. So he suggested I check it in reverse and adjust it if it isn't the same. I have had the boat out 2x this year and low speed steering is much better but there is a little rear end drift still. I also notice that steering in reverse is non-existent so I am considering getting the Fangs from Jeff and installing those. Anyway, my main question is about adjusting the buckets. How hard is that to do and how do I do it? I found some topics on here but most were about doing something electronically.
