Throttle and reverse cable
Nandy
How dificult is replace the reverse cable and throttle on my 2014 Yamaha sx210... I went to a dealer and quoted me almost $600 on parts and $1,100 on labor!!!! Any video, Can someone’s will share?
Thanks, for any suggestions
I have the same problem...If someone has any videos that would be great. I've ordered all parts that the dealer suggested but they don't have time to install for another month so that's most of my summer..
Welcome aboard to both of you,
not sure why you chose the watersports forum to post this though,
check out the fAQ tab at the top of the page, changing cables are documented there, you can also use the search button at the top right for some good threads on it,
I was just replying to his post :) but after searching the FAQ I keep finding a dead link so if you would find it and share that would be awesome. I've been in there and can't find it.
I'm sorry I saw you were replying, the wrong forum comment was directed to the thread starter,
I just tried the links in the FAQ and they worked for me,
here is one,
otherwise you might try using the search button, top right of the page with some of the key words and members name and it should pull you up some more info,
