Gumbeaux
- Limited S
Quick heads up and looking for any tricks.
My throttles were not well synchronized...maybe 1/4 inch off at mid throttle to get the same RPMs.
So, I followed the procedure below. I found that with levers full forward, the starboard side was not at the full throttle stop at the linkage, so I adjusted. Just like the video...
But now the left throttle is fully an inch forward to get the same rpms as the right throttle.
Check my reasoning here: This means the right throttle is opening up more and I need to actually loosen that cable, right? And/or tighten the left one.
Point being, making the adjustment at the full forward throttle position does not always equate to synchronized throttles...
