Hezi
- Secaucus NJ
- 212S
In my new 212S I have the same problem as I had on my 2015 242 LS. The throttle will not stay in position for long and I have to make constant adjustments. For example, I set both engines to 6000 rpm a minute later, one drop to 5800. I find myself investing a good amount of time and energy adjusting the rpm. I am holdings my right hand on the throttle controls and constantly making small adjustment. The control itself look like the same mechanism between both boats and I am aware of the two tension/friction flat head screws which suppose to keep the levers in place. It's not working. Not before, not now.
Is this a known issue? I am starting to regret I didnt go with the SE model. This is such a pita! I like the same exact rpm on both engines. I usually set the power optimally for the conditions but than power get out of adjustment in a minute or less.
Anyone is dealing with this issue as well? Any solutions? Thank you for sharing!
