Throttle position sensor 2021
Ibeflyinhigh
Anybody know how to reset or recalibrate the TPS on a 2021 ar190?
Thanks
I don't think there is anything to reset - you can adjust the cable tension to make sure you're hitting full throttle, but that's about it.
What issue are you experiencing?
Only getting 7100 rpms
I've talked to 3 other 2021 190 owners who all are between 7300&7400. I guess it doesnt matter at this point. I just ordered a 195 today. Thank you anyways
Are you at higher altitudes? Thinner air means less power.
If you're not at higher altitudes, you should see 7400-7500rpm. I have the same engines and 7500 is typical.
You trading in for the 195?
do the ribbon delete for extra RPMs
1600 feet. I'll probably sell it privately once I get confirmation that yamaha will produce and deliver my 195.
