Lmcneely11
- Sugar Sand
- Tango
My gate was partially covering the jet nozzle at full throttle and begin vibrating and so I adjusted the gate so that it would open fully. Tonight I was out in the boat and going full throttle and it was running great with no vibration and then I thought maybe I should see how fast it can go and I push down on the throttle and it clicked a little and got stuck. I used the Killswitch to stop as I could not pull the throttle shifter handle back. I went to the gate and was able to wiggle it some up and down and so it did not appear to be stuck. I was finally able with a lot of force, able to put it back into neutral and start it, and again with a lot of force I was get it to move forward a little bit to get back on the dock.
At home I disconnected the gate cable and then tested the throttle control. If I jiggle it it moves the shift in and out. And if I use force it will move the throttle controlled on the engine as it should. But I have to use a lot of force. The cable does not appear to be broke and I feel like the issue is in the throttle control mechanism. any suggestions would be great as I want to take kids on the water tomorrow.
