djtech2k
- WV
- SX
I just got my SX210 back on the water after it sat for almost a year waiting on a part (transom replaced). I put it on the water for the first time yesterday. The left throttle was so hard to move that I almost couldn't move it. It is especially tight when moving from the neutral position to forward or reverse. Once you get away from the neutral position, it does get a little easier but its still very tight. I had to keep my hand on the throttle pretty much the whole time because even when I moved it forward, it would come back a little bit every time.
It was not this stiff when I used the boat last summer. So I am wondering if it could be related to something the mechanic could have done while replacing the transom or if it is tight because of not being used in a year. Is this something that just needs lubed or something?
