sastocky
- Ohio
Any recommendations or direct experience on exactly which thru hull fitting to use 2021 AR250 bilge pump? From reading it seems as though everyone is using a 1” OD fitting with a 3/4” barb for connection to the hose.
I am replacing the existing plastic fitting and installing a second bilge pump so I will be installing a second thru hull fitting.
I do know my existing hose is 3/4”. My new pump outlet is a 3/4” barb. I do not know what size hole is exiting on my boat. Haven't removed it yet.
