Jmulvihill
- Blue Ridge, TX
- SS
We bought a 2014 212SS last fall with the twin 1.8L HO motors with about 120 hours. After the purchase, I was doing more research on here and read about the TC issues with the '14 and pre-07/'15 1.8L engines (I guess on both the HO and SVHO motors across boats and jet skis). If I have been lucky enough to see all of the posts on here via search, the topic seems to have died off after 2016/17 and I am not seeing a huge number of people posting that they are having a huge number of these failures in the boats (skis seem to be more prevalent, but those posts have also gone down it seems).
I saw the poll that was taken, and saw that there were 57 responses with 18 people who had 2015 or older boats, and 6 of those who had the timing chain issue. Is there any info with regard to the SN of the motors that are of greatest potential issue? I assume that if it was for the entire 2014 year models for those 1.8L HO motors across all of the Yamaha boat models, then it is just somewhat of the luck of the draw as to whether it would happen. Trying to see if it is really a big issue or just one of those things that seemed to occur but is not any higher than other potential failures.
Does it make any sense to have the motors retrofitted/fixed with the new parts before a failure? If so, any guesstimates as to the cost per motor? I heard that it requires a new TC, TC gear and crank shaft (I guess the crank has the TC gear permanently attached), so it is not an insignificant fix and probably why it seemed like Yamaha just replaced the whole motor on boats where this occurred. I have not seen the cost for a full motor replacement containing the new, beefier TC either. Just trying to better understand this in a new level of detail before our first season with this boat starts up. Right now, I plan to use it as normal and let the chips fall where they may as it does no good to fret over it and may never even happen. We are pretty easy on our gear anyway, so if it is a stress kind of failure from wave jumping and loading/unloading the pumps at WOT, we may be lucky and avoid the issue as that is not how we usually run things.
Thanks all!
Thanks all!
