2kwik4u
- Buffalo, NY
So I've lost my license plate 3 times in 4 seasons. I'm not sure if the people around me at the ramp parking areas can't drive, or if I'm clumsy and keep running into things or what. I've been very fortunate in that the local park rangers, or check-in station has had my plate each time I've lost it. Good Samaritans must outnumber bad drivers?!?!
Anywho, I've replaced the plastic mount a few times, then finished out last season with some safety wire in complete "just get me to the lake 3 more times" fashion. Well this spring I did something about it. Drew up a mounting bracket and had the guys in the shop laser cut me the shape out of 3/16in 316L stainless. Mounted it up today, and it's absurdly sturdy for holding a license plate. So stiff that I'm somewhat concerned I'll bend the trailer bracket before bending the plate.
Here's the bracket before installation. I made it shaped to pull the license up tight to the light vertically, and to be aligned with the edge of the trailer bracket horizontally. The "top two" holes match the pattern on the back of the trailer lights, and use those holes/studs to keep it in place, replacing the crappy plastic piece that was in there before.
Here's the crappy old plastic bracket as I was taking it apart.
Here's the new bracket in place. It's much more robust than I expected.
This is where the license plate will live. Still have to get some 1/4-20 stainless hardware to hold the plate in place. Going to go with security lock nuts this time too in hopes of it surviving the vibration at the end of the trailer.
I'll be happy to send the CAD file to anyone that wants it. It's pretty easy to make overall, and I would expect any local shop that has a laser cutter could make it for you in short order. I can even ask here if we can make a stack of them if there is enough interest. Not sure if everyone has this problem, or it's just me?!?!
