TLC for 2006 Sugar Sand Extreme
rynmcfad
Sugar Sand
Tango Xtreme
Here is a bit of a novice question but, I have had a 2006 SS Tango Extreme purchases new in 2006 which is garage kept. I have had it serviced about 5 years ago and ever since have only used it 25 or less times over the past 5 summers. As i am gearing up for this summer i feel as if my luck my be running out and need to give the engine some attention. Do you have any suggestions on fluids, filters, spark plugs, or anything along those lines i should be replacing or checking before use this summer? Currently, the fuses seem to have went since most of the electronics are not working (bilge, lights, radio). I am guessing replace fuse panel for that one? Appreciate any feedback and i apologize for my "newbie" type questions.
also get some white smoke on startup... i hear mixed messages on this. Some say its normal with a 2-stroke and others say it should be very minimal.
