Too heavy of an anchor
gthh
Buffalo, NY
Need an opinion. I lost my 13 lb box anchor which was perfect. A lot of anchors must be stowed in Davy Jones locker this summer because Amazon is all out!
So I thought what’s 12 more pounds and got a 25lb monster. To heavy for our boats?
Thanks
I have a 25lb. Richter anchor. It's a serious bitch to pull up sometimes, but my boat DOESN'T MOVE 99%of the time on anything but a totally rocky bottom! It still fits in the anchor locker. ?
3' of chain on it btw.
I Use a 30lb River anchor with 5 ft of chain For 192 boat. I stow it in a milk crate. great work out pulling out of water. In addition I have been using an anchor monitor and it holds on those windy, chopy days or the not so great spots with boat traffic.
We use a 20lb box anchor w/6’ of chain and our new mantus w/4’ of chain at the aft... We don’t move anymore ? you’ll be fine with it as long as you sort the storing to your liking...
Bought a 4 lbs Fortress danforth style anchor...I can toss it like a grapefruit and it's so easy to pull up as it weighs so little - the mud usually weighs more. Holding power is really good. Only issue is that it's so light that current and seabed material affects how it lands on the seabed and sometimes the flukes stay up and won't dig in. Even so, it's so light I can't knock it.
:D
I have both 8lbs and 13lbs Mantus. The 13lbs holds amazingly well, but it's a bit of a bear size wise. The 8lbs is awesome EXCEPT in this one area where the 13lbs holds fine but the 8 won't hold the first time (sometimes 2 or 3 tries, so I don't use the 8lbs anymore) I will be experimenting with a 4lbs FX4 I just got as a secondary/lunch hook to see how effective it is.
I used to have a 20lbs Navy anchor that also holds every time the first time. The issue is lower holding power against very large swells. It would get unhooked. it holds again right away, but I was loosing 5-10 ft on every big tanker passing by. In sand, the mantus (even the 8lbs) holds better than my navy did. If you boat mostly in sand I bet you would be super happy with the mantus 8lbs. Best of Luck.
Have a featherweight fortress anchor with 10' of chain. Easy to toss and retrieve, and when properly set will hold at least two boats in strong wind and current. Proper deployment and scope is way more important than weight.
Thanks Gents! Always good to get a round of opinions from the best!
I will be getting the beast this Thursday.
I attempted to dive for the anchor in the area I lost it but visibility was 12' or less and no joy on that effort but someone told me about a recovery magnet.....
Thanks again
