Konnie
- Tequesta
So replaced the oil in both engines about a year ago.
Notice a few weeks later that there was some oil in the port side breather box.
Air filter looked fine.
Cleaned out the breather box and suspected that I may have over filled the port engine when replacing the oil.
Notice the port engine dropped in rpm, like 2-300 rpm, now and then over the past year but never lasted long so did not care too much about it.
Couple of weeks ago the port engine dropped more severely in rpm, like 1000 rpm, and lasted for about 20 second each time.
It happed on and off for a day.
Suspected a bad spark plug.
Replaced the spark plugs in the port engine this past Sunday, noticed oil in the breather box again.
Cleaned in it out. Old plugs looked old but not horrible and all about equally worn.
Oil level is at the "L" mark when cold and on the trailer. Approximately the same level for both engines. No oil in starboard breather box.
Went for a ride after the plug replacement. No severe drop in rpm but maybe minor drops in rpm a few times.
Found oil in the port side breather box when I got home after the ride.
Also, at one instance both warning lights for overheating came on approximately 30 seconds apart as I was going about 2500 RPM for the last 20 min or so.
Just surprised that both lights came on approximately at the same time as the cooling is independent between the two. Which makes me suspect an electrical issue.
Thoughts on this mess?
Is overflow of oil caused by a bad fuel injector and or bad ECU pushing gas into the oil making it overflow into the breather box or just simply too much oil?
Or something else?
I tried to smell the oil in the breather box to see if it smelled like gas but could not detect any distinct smell of gas but I'm no oil connoisseur...lol.
Any input is appreciated!!
Or something else?
