surfer212
- Hartford, CT
- 212XD
Wondering if anyone here on Jet Boaters has experienced the same issue I just discovered. I have a 2012 212X with the 1.8 L HO engines. The Deflector Nozzles are: original Part # 65B-51313-10-8S, replacement Part # 6AP-51313-10-00. While doing a walk around inspection before splashing in this Summer I noticed quite a bit of play or looseness at the bottom bolt / bushing location, not so much at the top. The bolts and bushings are available and inexpensive but I wanted to check to see if anyone else has experienced a similar issue. I'm curious how much play in the assembly is normal, whether replacing the bushings reduced the play, and if anyone has disassembly / reassembly instructions? I'm guessing the bolt will need loc-tite to keep it in place - it would be good to know which type to make sure it doesn't back out over time.
Thanks in advance...
