Torque specs for jet buckets
MillsyMO
I’ve got a rattle at idle. I checked the engine compartment and all over the aft of the boat on the inside and it seems to be coming from under the boat on the aft. I’ve shut each motor off with the other running and it continues to rattle either way.
Out of the water the starboard bucket has quite a bit more play than the port side. I don’t want to blindly tighten it up and cause a performance issue so I’m hoping someone has the correct torques specs so I can check mine to see if it’s loose or if it’s good I can continue my search for the rattle. Thanks
