- Northern Vermont Lake Champlain
- Boston Whaler
- Other
My yearly inspection was due in Feb., but the truck needed a few things replaced in order for it to pass. Not having a heated shop, 3 bay garage/storage full, I needed to wait for warmer temps. to do the work in the arena. Let me say that the winters are tough on cars and trucks up here with the snow and ice and all of the salt and brine the State and Towns put on the roads to keep them clear. It does not take long for rust to set into fenders, rockers, cab corners and truck beds. Any holes in any of these parts will fail your vehicles inspection. My truck had some rust holes growing. Instead of trading her in, only 150,000 miles on a Duramax, I decided to rebuild the bed, body and any suspension parts required to keep her for a while longer. The truck money went towards buying a Beneteau First 35s5 sailboat to add to the Yamaha. Ya, I was given the choise and I chose the Bene. I am pretty much done now, she drives and looks much better now, even though she is three colors, not painted yet. So here are some pics. along the way.
Before
Some new metal
Started by removing the rotted bed.
And the rusted rockers
Then started fitting the new body metal
Then welded into place and used a little Bondo to smooth things out.
Painted/undercoated and started work on the bed.
I really like the aluminum beds but not the price at $3k plus. So having a few oak logs and a sawmill, I decided to make one. I know, but it still is a farm truck and if a board rots, I can make a new one. I just need it for towing the boat and stock trailers as well as 12,000# hay wagons up Hardscrabble Hill.
Still working on the bed, adding a tailgate and ladder rack. Other parts changed out included fuel pump sending unit and fuel filter housing, cross member for transmission mount (rotted), changed upper/lower ball joints, inner/ outer tie rod ends, front brake calipers and other stuff I will remember later. Got to go get the new tires put on now, so I have to go.
Before
Some new metal
